Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: Newbie Question about Knock Retard
  1. #11
    Quote Originally Posted by Powerhouse
    Here is the log file. It's towards the 11.12.37sec mark.
    http://files-upload.com/389731/Log_0001.efi.html
    You HAVE to click on the link. You can't right click save as..
    Oh, you can post your log directly in the forum thread (press Manage Attachments).
  2. #12
    Ok, I applied the LC-1 AFR/BEN calc pids, and your actual AFR got better, it's closer to commanded AFR...
    but, if VE/MAF/IFR were dialed in, actual AFR would [pretty much] track commanded AFR closely.
  3. #13
    Jul 2007
    Is it still unsafe?
  4. #14
    Jul 2007
    Also.. It has Speed Density so the Maf isn't plugged in
  5. #15
    Is it still unsafe?
    I would investigate that knock... especially if you use nitrous.
    For nitrous you need AFR as rich as low 11's, but I'm not an expert on nitrous.
    You can't hear it knock...?
    You may want to check/replace your knock sensors and knock sensor subharness; do you get any DTC's...?
    Have you been tuned for your mods...
    in particular:
    - injector need IFR table to be recomputed;
    - cam, intake, tb need VE table to be dialed in;
  6. #16
    Do you calibrate your LC-1 (heater cal, and then free air cal)...?
  7. #17
    I think your timing's too high (again considering nitrous) and your AFR is a little lean in some places.
  8. #18
    Jul 2007
    I just bought this car last weekend... This software was included and the guy seemed knowledgable about it. I just want to make sure the tune is good. Im a total newb with Efi Live. I don't remember hearing any knock.. I guess I could pay a little more attention to it.
    I tried to pull my tune but it said it couldn't read the pcm. Im updated Efi live so maybe thats all it is. I'll load it up when I get it
  9. #19
    Read the LC-1 manual and follow the heater cal and free air cal procedures:
    http://www.innovatemotorsports.com/s...C-1_Manual.pdf
    Do you have the DB-9 to stereo connector for connecting the LC-1 to your laptop...?
    Download this version of EFILive software (download the zip, follow the instructions on this page):
    http://forum.efilive.com/showthread.php?t=5707
    It may be a combination of a little too much timing and valvetrain noise.
    Do you have EFILive FlashScan V1 (has no LCD) or V2 (has LCD)...?
  10. #20
  1. Knock Retard follows RPM
    By vortecfcar in forum Gen III V8 Specific
    Last Post: June 1st, 2008, 05:02 AM
  2. Knock Retard GM.KNKRET vs Retard Due to Knock GM.KR
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2008, 03:18 AM
  3. Knock Retard
    By NAH in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 21st, 2007, 10:15 AM
  4. Knock Retard
    By NAH in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2007, 06:29 AM
  5. knock retard
    By blackblowngto in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2005, 10:50 AM
