Results 1 to 4 of 4
Thread: Tire change for track question
    Default Tire change for track question
    I want to run a lighter/smaller wheel at the track(245/70/17). do I just need to make changes on the tire size within my tune to adjust for the difference from stock wheels(305/40/22)?
    Thanks, Jeremy
    Jun 2005
    Yes. Two things though:
    1 - If it's an auto, I'd suggest saving the alternate tune seperately as it will affect your shift tables. You bounce those back and forth a couple of times and they may end up in a different spot from where you started. If it's an M6, then yes just enter in the new info.
    2 - Calculated tire height is ok. Measured tire height is better. Break out your tape measure.
    Quote Originally Posted by SSpdDmon
    The tires will be for track only so I'll save the tune. How will this change my shift tables? I'll make suer to measure the wheels before entering the data into my tune.
    Jun 2005
    It'll change the shift tables for A4's by computing a % difference between your current tire and the new one. Then, you apply the change.
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. Change a tire ...
    By Garry in forum Lounge
    Last Post: September 21st, 2008, 06:07 PM
  3. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
  4. front tire change on a C5?
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2005, 02:15 PM
  5. Tire size change calulation
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 08:52 AM
