Results 1 to 7 of 7
Thread: EFILive And VT
    Jul 2007
    Default EFILive And VT
    I have got the cable and software working with my VT V6
    Now what can I do with it ??
    Jul 2007
    Hello Hello anyone there
    Oct 2004
    There's no complicated answer to this. It is a Scan Tool so you can scan the supported PIDs - that's it really
    Andrew
    EFILive Crew
    Jul 2007
    CAn you get the Error codes from your car with this program ??
    Oct 2004
    I'll PM Paul a link to this thread as he knows the most about it. I don't have a test vehicle or PCM to try it out.
    Andrew
    EFILive Crew
    Quote Originally Posted by DND
    Yes, load the vehicle config file: gmh-vt6.xml using menu option: File->Select vehicle. Then select the third macro "Engine Data and DTCs (DATADTC)", (DTC= Diagnostic Trouble Code).
    Then click on the green start logging button to log the current state of the DTCs. You can view the DTCs' status on the [DTC (F10)] tab page.
    Jul 2007
    thanx I'll have ago
