Results 1 to 5 of 5
Thread: Car dies when I turn on the A/C
    Jul 2007
    Default Car dies when I turn on the A/C
    If I were to turn my car on with the a/c on, it will idle funny and die. So I HAVE to turn it off to start the car.. but when I turn it on after that, when coming to a stop, it dies. The idle goes up and down and it dies. Only after driving for about 10-15min. can I turn on the a/c and it be okay 90% of the time. What is causing this? I attached my tune.
    Jun 2005
    Goto System>A/C and increase the torque loss table until it runs right.
    I had to bump mine up close to 80%.
    Jul 2007
    The only thing diff. I see from your tune is the A/C Enable TPS and the A/cEnable time. The A/C Turn on and off Delay are the same as mine.
    Oct 2006
    Have a look at how many steps your iac motor is at idle with the scan tool. If it is maxxed out no adjusting of the idle airflow correction tables will help. Also there is calculated pids in the scantool for airflow correction aircon on. Log these with the corresponding pids & it should help you find the problem. Also have a look at A/C spark correction.
    Jul 2007
    n/m i found it. I have to charge my laptop and I'll give it a try...
  1. to turn off AIR pump
    By Kurtomac in forum Gen III V8 Specific
    Last Post: May 19th, 2008, 12:33 PM
  2. RR dies
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 10th, 2007, 09:01 PM
  3. How do I turn on the charts?
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 6th, 2006, 11:32 AM
  4. Car Dies With A/C On
    By vetteboy2k in forum Custom Operating Systems
    Last Post: July 27th, 2006, 01:31 PM
  5. Car just dies
    Last Post: April 8th, 2006, 04:05 PM
