So I've been at this for a couple of days now and I can't seem to crack it. As of now the car idles pretty decently, and seems to drive alright for the most part, but it turns into a bucking bronco at low throttle/no throttle in the idle-2000rpm area. Once the RPMs get a little higher, or if I give it a little gas, its smooths right out, but cruising down the street is hardly possible under 2000 rpm. Starting from a stop isn't bad, but once the clutch is fully engaged <20% throttle and under 2000rpm is just bucks a little, and then gets worse an worse until I have to either give it gas or put the clutch in.
AFR is in the mid/low 14s, I've tried a little richer and it didn't seem to matter. Spark advance in in the mid 20s to low 30s, and I've gotten it to stay pretty steady when I'm getting the surging, I've tried adding a little timing, then more timing, until I started to get to the knock threshold, and it hardly even makes a difference. I've done the RAFIG process a couple of times, tried adding a bit to the desired airflow, no change. Right now the desired airflow is about +0.5 from what I've gotten logging the pid. I've tried playing with the throttle cracker/follower, but I'm having trouble figuring out what to change, but so far nothing I've done has done much to help the surging. I've also drilled a bigger hole in the throttle body, and the IAC counts are around 50 at a warm/no load idle.
Car is 3000lbs, with a 4.1 final drive, 232/240 112+4 cam, stock heads, bolt-ons motor. Running open loop speed density until I can get the tune mostly worked out.
I'm guessing the car just wants more air in that area, but I really don't know how or where to give it...nothing I've tried so far has made a bit of difference
