Results 1 to 3 of 3
Thread: Linking Scan Log To Tune File Maps
    Mar 2005
    Default Linking Scan Log To Tune File Maps
    Hi people, just doing some preliminery logging on a 2007 Holden SSV with an E38 PCM and for some reason when I highlight the scan tool data I'm not getting the purple highlight in the corresponding map in the tune software.
    It still works with LS1 logs and maps but not the new E38.
    What am I missing? just spent 2 hours looking and I've had enough
    knowing me it will be right in front of me > MAN LOOK
    Mike
    "Just a tune > yeah right !!!! "
    The E38 links have not (yet) been added to the configuration file:
    \Program Files\EFILive\V7\Configuration\cal_link.txt
    You can add in whatever links you want to use by adding entries in the [E38] section. Look for the [E38] section header. For example here's how you would add the spark table link:
    Code:
    ; _________________________________________________________________________
    ; E38 (LS2 2006/2007)
    ; ROW runs Vertical - Y Axis
    ; COL runs Horizontal - X Axis
    [E38]
    ; High octane spark table
    B5101.ROW=SAE.RPM
    B5101.COL=E38.APCYL_DMA
    Mar 2005
    awesome thanks Blacky
  1. larger tune maps
    By limited cv8r in forum Tips and tricks
    Last Post: July 17th, 2008, 04:15 PM
  2. Scan Data vs Tune maps? HELP
    By Wichita Dyno in forum Gen III V8 Specific
    Last Post: September 25th, 2007, 05:48 AM
  3. Linking Logs to tune?
    By Cougar281 in forum General
    Last Post: August 4th, 2007, 10:31 AM
  4. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
  5. linking scan data to tune file
    By a78turbo in forum Duramax LLY
    Last Post: March 14th, 2006, 04:53 PM
