Could someone maybe send me the spreadsheet in the sticky? I am having trouble with the link.....thanks
Thanks Joe, but I keep getting "Access to the specified device,path.or file is denied"
Try this one...
2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
Flashing control modules since 2001. 8-)
Who needs a MAP sensor on a supercharged LS6 anyway.
I tried clicking on it....no good. I right clicked it and saved file as. (It is in Excel yes?) When I try to open it is says "file not found"
I had no problem with it. Right click save as and add .xls to thefile name.
Must be on my end somewhere, I will try another computer.....Thank you all !!!
I got it to open, I needed to update Excel
98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
Ok now I have the file working, anyone know if my Motron 60 lb injectors are rated for 43.5 Lbs of pressure? Thanks
