Results 1 to 10 of 13
Thread: Calculating Injector flow rate
    Apr 2007
    Default Calculating Injector flow rate
    Could someone maybe send me the spreadsheet in the sticky? I am having trouble with the link.....thanks
    Try this...
    Apr 2007
    Thanks Joe, but I keep getting "Access to the specified device,path.or file is denied"
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Try this one...
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Apr 2007
    I tried clicking on it....no good. I right clicked it and saved file as. (It is in Excel yes?) When I try to open it is says "file not found"
    Oct 2006
    I had no problem with it. Right click save as and add .xls to thefile name.
    Apr 2007
    Must be on my end somewhere, I will try another computer.....Thank you all !!!
    Apr 2007
    I got it to open, I needed to update Excel
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Apr 2007
    Ok now I have the file working, anyone know if my Motron 60 lb injectors are rated for 43.5 Lbs of pressure? Thanks
    I believe they are.
  1. Calculating Injector Flow rate
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2012, 04:22 PM
  2. Injector flow rate
    By sinr98 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2010, 04:59 AM
  3. Injector Flow Rate
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2009, 10:22 AM
  4. Injector flow rate
    By billiardcue in forum General (Petrol, Gas, Ethanol)
    Last Post: March 13th, 2007, 04:33 PM
  5. injector flow rate question
    By 9secVette in forum General (Petrol, Gas, Ethanol)
    Last Post: May 24th, 2006, 02:04 AM
