Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Auto VE questions
  1. #21
    May 2006
    Quote Originally Posted by SSpdDmon
    #1 - (helpful tip) You shouldn't be logging more than 24 channels. It kills resolution in your logs. You have 33 channels tied up there.
    #2 - Your map (any map) should look like the table in the tune that your trying to change. You should only have one column. For RAFIG adjustments, I made my column RPM referenced with ",8000" as the label. The rows should be labeled the same as the table in the tune (ECT's in the grey boxes on the left). The RAFIG pid is your data. But, the kicker is, I don't really use the map feature when changing desired idle airflow. I look at the charts on the dashboard's second page (page B). If you highlight a group of frames, it will display the high, low, and average for that selection. I use that to quickly determine the average RAFIG for a given ECT.
    #3 - The average correction for each temp based on the log you attached should be as follows:
    32*C = 0.00 (no correction in log)
    44*C = +2.10 (add 2.1 to your table)
    56*C = -5.10 (subtract from your table)
    68*C = -3.80
    80*C = -3.00
    92*C = -3.00
    I Apologize for the newbie question and maybe I'm just dense, but when you looked at the dashboard and read the data, which parameter did you interpret? I figured ECT, but wasn't sure. I understand the highlight part, but how did you know where to highlight?
    Once again, I Apologize for the newbie question! I'm still just trying to learn some of this.......It's coming VERY slowly though!
    Thanks for the help!
  2. #22
    Jun 2005
    Quote Originally Posted by FreddyG
    The easiest way is to create a simple filter. If you're looking to change the 176*F cell, I would exclude data where ECT is less than 175*F and greater than 177*F. Then, the average RAFIG is the pid you interpret to determine how much of a correction you need to make.
  3. #23
    May 2006
    Thank You SSpdDmon! I'll try that!
    What pid's should I log for the RAFIG and RAFPN besides these:
    How long does it take before learning this gets easier?
  4. #24
    Jun 2005
    N/P
    You only have to log 3 of the 6 - the in gear OR the p/n pids. If your car is an M6, then you only have to do the in gear side of the table as the p/n stuff isn't used.
    As for how long it takes to learn easier...I can't help ya with that one. I've been using the software for 2 years or so and I learn something new every month still.
  5. #25
    May 2006
    N/P
    Thank You once again for the help SSpdDmon!
    So let's see it took you 2 years to get where you are, then by about 2015, I should have the hang of it! Maybe 2012 if I get a RoadRunner!
  6. #26
    Jul 2003
    I am still wondering if we have any A/C ON parameters for this.
  7. #27
    Junior Member ItzNota's Avatar
    Oct 2008
    Quote Originally Posted by SSpdDmon View Post
    I probably should have been more clear earlier...responses have been edited.
    In the 'map' view, the cells for each ECT will average the range between the various ECT's on the left. For example, the average RAFIG correction in your map for 44*C (-1.328grams/sec) is really the average correction for all temps between 38.1*C and 49.9*C.
    What I explained to do was to look at 44*C and ignore all of the crap inbetween. When you filter out the data to show only 44*C, the average correction shows a different story (+2.1 grams/second). That's the data you want to use and that's why my number is different than yours.
    What the hell am I doing wrong on mine??
    I have been reading over and over what you have said and it does NOT look like I am pulling the right numbers here!
    I am frustrated as all get out.....any help here would be appreciated guys. I need to nail down this idle..it's driving me bonkers!
ID:	4154   Click image for larger version.
ID:	4155   Click image for larger version.
ID:	4156   Click image for larger version.
  8. #28
    Oct 2006
    Quote Originally Posted by ItzNota View Post
    What exactly is your issue?
    The log supplied is very short & will only supply data for the two cells in which no need for correction is evident.
    The Tremor at AIR
  9. #29
    Oct 2008
    Quote Originally Posted by 5.7ute View Post
    Am I not letting it go long enough??
    I just feel like it is not setup correctly...
  10. #30
    Oct 2006
    It appears to be set up correctly however something does appear to be wrong. Your idle is falling with temp & no correction is being logged.
    There was an issue a while ago posted on this forum by macca779 that I will try & find.
    I assume that this car of yours is electronic throttle. Is this correct?
    The Tremor at AIR
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 07:06 AM
  2. Auto VE ?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 15th, 2009, 08:00 AM
  3. Converted from man. to auto OS questions...
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 15th, 2008, 02:05 PM
  4. Auto VE questions
    By 98ls1blackbird in forum General (Petrol, Gas, Ethanol)
    Last Post: August 23rd, 2007, 01:08 PM
  5. Couple of Auto VE questions/observations
    Last Post: April 30th, 2007, 11:11 PM
