Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: SD/Open Loop Script
    Jan 2004
    Default SD/Open Loop Script
    I made a script that does the following and thought I would share it for anyone that would be interested. It pretty much gets you set-up for a Open loop/SD tune. Here are the fields that it changes
    Disable LTFT
    Disable DFCO
    Disable PE
    Adjust Open EQ Table (14.63 Cruise/12.9 WOT)
    Adjust DTC's (Disable Rear o2's, EGR, etc)
    Disable EGR
    Set MAF Rationality to 0 (Disables MAF)
    Disabled COT
    If someone see's anything I have missed, please let me know. I am trying to write a basic script for putting the car in Open Loop/SD and will be working on one for Closed Loop/SD.
    File is below
    Jul 2005
    Do you still have a copy of this? the link doesn't work. If you do could you email it to me at blacksaleen95@charter.net Thanks!!!
    Senior Member AllCammedUp's Avatar
    Jun 2003
    The link still doesn't work - any way we coudl get another copy? Thanks!
    Whitney Roberts
    Jan 2004
    Give me a second guys. I'll get something worked up for you.
    Jan 2004
    I redid the script and think it is all there. You need to MAKE SURE that your display units in the editor are set to default.
    Jun 2003
    Thank you!!
    Whitney Roberts
    Jul 2005
    When tuning in SD should you tune to 13.0 across the board or 14.7 @ idle and cruise & 13.0 @ WOT?
    Phil
    Oct 2004
    Quote Originally Posted by Phil99vette
    Phil
    Prepare to get some different opinions on this one
    My $0.02 is to look at the {B3605} EQ Ratio When In Open Loop table and make sure that looks right. This is after all the table that will be referred to when in Open Loop mode.
    This way the commanded AFR will normally be 14.61:1, except when directed by this table (i.e. higher RPM vs. MAP points).
    Personally, I have tried both ways, and my personal experience has been that if I command 13.0:1 at all RPM vs. MAP points, when I change back to commanding 14.63:1 the BEN Factors are out (albeit slightly).
    Bottom line, I guess you are going to get pretty good results which ever way you choose!
    Andrew
    EFILive Crew
    Nov 2003
    Quote Originally Posted by black02ss
    How do you run a script? Do you run it from a command prompt or from inside FlashScan or before you run the .exe or with the .exe /script? I did not see anything in the manual about running scripts.
    Thanks,
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Sep 2003
    There is a play icon in the Flashcan tool bar when you hit it you will have to direct it where the file is located after you click run it will make the changes and you will be good to go
    Larry - HumpinSS
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. program is changing open loop to close loop
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2007, 06:38 AM
  3. Open loop or semi open loop still?
    Last Post: October 18th, 2007, 03:46 AM
  4. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  5. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 05:25 AM
