Results 1 to 7 of 7
Thread: No connection
    Jul 2007
    Post No connection
    I have a 69 Camaro with an LS1/T56 from a 2001 Camaro in it. I have now a problem were I can not connect to the PCM. Efi Live says that it cannot connect to the PCM and try to turn off ignition and so on.
    I have tried with another scandevice to se if anything is wrong with my cable or Flashscan and it didn't work either.
    So how can I go forward in my search for faults. The pins 2 & 16 on the connector has voltage when ignition is on. Pin 16 has voltage when ignition is off as expected.
    The connectors Pin 2 is connected to the C230 plug pin K.
    Since I have voltage on Pin2 doesn't that mean I have signal?
    I should also say that the engine is working and runs OK.
    Any help is appreciated.
    Jan Suhr
    Stockholm, Sweden
    1969 Camaro LS1/T56 Protouring Z/28
    www.protouring.se
    I believe you also need ground connections on pins 4 and 5.
    Jul 2007
    Yes, they are of course connected to ground.
    Jan Suhr
    Stockholm, Sweden
    www.protouring.se
    Here are the PCM circuit diagrams for 2001 F-body...
    87623186.gif shows the DLC connections...
    Do you have anything else connected to circuit 1049...?
    Jul 2007
    It is connected like that schematic.
    I have had connection before and made a scan with Efi Live. I did also some changes like removing VATS and the O2 sensors after the cats before I started it the first time. Then everything worked as expected.
    Now it doesn't.
    Since I have voltage on Pin2 I assume there is a signal, or?
    Jan Suhr
    Stockholm, Sweden
    www.protouring.se
    Quote Originally Posted by jannes_z-28
    Now it doesn't.
    It's hard to say because the signal is VPW (variable pulse width squarewave)...
    If you have a scopemeter, you could see if it was a steady voltage (bad, maybe shorted, or bad PCM) or a variable square-like waveform (good).
    Jul 2007
    Ok thanks,
    I'll try to find a scope and see how it looks.
    Jan Suhr
    Stockholm, Sweden
    www.protouring.se
  1. Not connection to E67 ECM
    By khalidmmukhtar in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2010, 07:40 AM
  2. LC-1 serial connection
    By nathans1987 in forum Tutorials
    Last Post: May 26th, 2009, 10:08 AM
  3. No connection!
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 11:33 AM
  4. Problems with V2 Connection
    By SV8346 in forum FlashScan V2
    Last Post: February 26th, 2008, 11:44 AM
  5. LC1 losing connection.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2008, 12:28 PM
