Results 1 to 10 of 17
Thread: Map Kpa Labels For 2bar
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Map Kpa Labels For 2bar
    Is it possible to change the Kpa Label for 2 bar tuning in the various tables? This software does everything else just wondering if its possible for a simple minded guy like myself????
    The auto-tune is pure Genius, it works slicker than dog snot..
    We're working on it.
    Mar 2005
    Just lookng for some grease...lol
    Mar 2005
    Quote Originally Posted by MN C5
    Any closer....Rumor has it coming the 1st week of August with a bunch of enhancements....for boosted tuning
    Rumours are correct, though they might even be released before then, fingers crossed.
    Mar 2005
    Very cool... I'm very glad I went with Flashscan. I'd still be holding my breath for V2.0 from the competion..
    I'd be a happy beta tester if you need one
    Aug 2005
    the 2 bar setup will just be a download? when will this be available? i was under the impression that it was already part of the system i purchased a week ago. i have the commercial scan and tune. i am trying to tune a blown gto, any update yet?
    Quote Originally Posted by blackblowngto
    2 bar code will be a download but you will still need to tune the boost tables , if you have already done a 1 bar tune N/A SD with the bigger injectors the bae tune will transfer straight over , if not you will need to do a full tune both 1 bar and 2 bar - not really something for the novice to attempt as there first tune.
    As a starting point I woudl recomend disconnecting the blower when you are starting to go to a 2 bar tune ,add the 2 bar map sensor then tune the car 100% up to 100kpa , once you have it all running sweet then attatch the blower belt and continue on from 100 kpa to 200 kpa
    You can tune your GTO with a 2bar now if you wish, do you have a 2bar sensor on the car yet?.
    Mar 2005
    Its very easy to tune for the 2bar map. You just need to understand your map scale needs to be adjusted... i.e. 50kpa on the column header is now 100kpa ect...
  1. To 2bar or not
    By Slowrc in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 12th, 2010, 04:24 AM
  2. e38 2bar sd
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 28th, 2008, 06:17 PM
  3. 2bar with mac e67?
    By SScarTuning in forum E37, E38 & E67 PFI ECM's
    Last Post: October 27th, 2007, 08:12 AM
  4. 2Bar ?'s
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2005, 01:15 PM
