Results 21 to 30 of 43
Thread: Idle timing tables
  1. #21
    I did make quite a number of additions to the LB7 / LLY tables (as promised) after SEMA. However there is something odd going on with the LB7 / LLY cals at the moment that I have not been able to figure out.
    The problem is the 3D tables are showing up as 2D only, it's only affecting some users and some OS's though.
    I'm away at the moment (I'll be back on Monday), I'll post up the cals in here for you all to try, you might be lucky and everything will look fine.
  2. #22
    May 2006
    Thanks Ross!
    05 LLY CC/SB D/A, EFILived to the tune of 530rwhp.
  3. #23
    It's only been a year in the making
  4. #24
    How close to release are the beta cals for the 5sp Allison TCM? Are you planning on posting them up when you get back too?
  5. #25
    May 2006
    Any files ready for us yet Ross?
  6. #26
    See here -
    http://forum.efilive.com/showthread.php?t=7097
    However, I have not found the specific P/N to Gear idle tables (if there is some). I think what it is might be the commanded fuel rate is causing the problem. Eg, too much difference between P/N and In Gear therefore the commanded mm3 used in the timing lookups varies greatly.
  7. #27
    Oct 2005
    See here -
    Ross,
    this is very unlikely as I get a timing that is nowhere near any number in the entire timing table. Timing drops to e.g. -5° and all table values are positive. I can send you a tune and a log file if you like.
    Lennart
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
  8. #28
    x2,
    the -5.1 (warm) seems to be prevalent. It is higher (and noisier) when cold IIRC.
    One thing that changes when changing gears from P, to D....is LOAD.
    Ross did you get my unrelated email a week ago? Sent a copy to Paul.
    Custom Tuning Services
  9. #29
    Lennart, a log would be great thanks.
    Killerbee, I don't recall getting anything (or being forwarded anything from Paul). Mind you, I have my spam filter turned up way high now, it might have got junked.
  10. #30
    Oct 2005
    It might be possible that we are not looking for a big table, so far the typical numbers from 0°C to 62°C are 8.0 or 9.0 deg and then from 71°C up -4.0 or -5.0 deg.
    Not sure where the exact temp is when it switches from high to low.
    Will hook up a pot and simulate ECT while the truck is in drive to get the full scale to you.
  1. Difference between (A) and (B) timing correction tables (LBZ ONLY)
    By bballer182 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 12th, 2010, 01:51 PM
  2. Confused...Timing tables changed
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 7th, 2009, 02:43 PM
  3. Timing tables question regarding B5913 and B5914
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2007, 07:57 AM
  4. Optimized VE and Timing tables
    By neil in forum Gen III V8 Specific
    Last Post: October 14th, 2007, 12:35 PM
  5. Can the timing tables 'x' axis be changed
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2007, 07:54 PM
