Results 1 to 10 of 10
Thread: Problem Flashing Pcm
    Jan 2007
    Default Problem Flashing Pcm
    Well I have been havin a problem tryin to flash my pcm in my 2000 Silvy. First time I tried flashing the truck it went fine till about 45 secs the flashing stopped and said there was checksum error. I will try and reflash truck and it tells me invalid calibration and quits. Then truck wont restart. This has cost me a license since I had to get a new pcm since pcm wasnt in deadpoll but was actually dead. Second time same thing happened but dealer was able to just reflash pcm. Has anyone ever had a problem like this? I have a LS1 bench harness and was going to try and flash it that way but why cant I flash it in truck? Well any help is appreciated, Thanks
    Here are the files...
    Jan 2007
    Anyone??
    I do have a spare pcm that I would like to flash with this tune just so I dont have problems. It is a pcm out of a 2002 Express Van L31 motor (12212156). Can I just to a full reflash and have a spare tuned pcm??
    Lifetime Member Doc's Avatar
    Oct 2005
    I would PM Paul with the Error file.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jake, I already pm'd Paul on your behalf...
    Jan 2007
    Thanks!!!
    What would help us the most to track down the problem is a copy of the trace log file of the failed reflash, from the folder:
    \My Documents\EFILive\V7\Bug Reports.
    The file will be called YYYYMMDD_HHMMSS_download.blx where
    YYYY is the year
    MM is the month
    DD is the day
    HH is the hour
    MM is the Minute
    SS is the second
    when you performed the reflash that failed.
    Jan 2007
    Well today i did a full flash with my bench harness and it worked fine. I had to relfash my stock tune because after shop had done a flash I was getting a trouble code P1631. After I did that I tried to flash a tune into the pcm and it tells me I need to license pcm. Why do I have to relicense the pcm?
    Quote Originally Posted by Jakes4321
    Try using this software version: showthread.php?t=5890
    Plus read this:
    http://forum.efilive.com/showthread.php?t=4093
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Paul, just a thought, but would it be possible to implement the ability to input your own serial number if this happens, such as taking the number off the label on the PCM and entering that? Not sure if it really matters,but just a thought.
  1. Flashing different OS?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:00 AM
  2. HUGE Problem after flashing
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 7th, 2008, 12:44 PM
  3. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 10:39 PM
  4. Re-Flashing Problem v1 7.3.2
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 8th, 2006, 07:53 AM
  5. Problem Flashing VY Ute
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: January 28th, 2005, 02:41 PM
