Results 1 to 10 of 12
Thread: LS2/LS7 Knock Sensors and LS1/6 PCM
    Oct 2003
    Default LS2/LS7 Knock Sensors and LS1/6 PCM
    GM should announce pricing on the LS7 Crate Engine next month. If it's not too severe in price I'd like to put one on my "wish list".
    I'm sure I'll ogle it for a while but eventually it will need to go in my car.
    Can you guys create a custom OS that reads, and interprets, the LS2/LS7 knock sensor output - so I can use my current LS1/LS6 PCM and the newer generation sensors?
    Just curious??
    Thank you.
    joel
    Oct 2003
    Is a hybrid OS, as stated above, feasible?? ...........
    joel
    I have no idea, sorry. :(
    Oct 2003
    Thanks for the reply, Paul.
    I'm sure GMPX will develope a work-around as the LS2/LS7 transplants become more common. I'm in no hurry - I'm just dreaming a little bit. :lol:
    joel
    Lifetime Member jfpilla's Avatar
    Joel,
    I should know in a week maybe two.
    Joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Oct 2003
    Quote Originally Posted by jfpilla
    Joel,
    Joe
    Thanks Joe!!
    joel
    Problem is the different style of knock sensor on the LS2 (but you knew that).
    I know the LS1 PCM has a specific chip designed to filter and amplify the knock sensor signals, you can bet the LS2 ECM uses a different chip because of the new type knock sensors.
    It is going to be a hardware issue, not so much the calibrations.
    Quote Originally Posted by GMPX
    There has been what, so far, looks like a successful use of the LS1 sensors with an LS2 block in an f-body. The sensors are in the LS2 block. An issue with f-bodies seems to be whether the sensors clear on both sides when using certain longtubes. I guess which longtubes are okay for clearance will have to be determined. The sensors can both be placed on one side, however. At least one hole needs to be tapped. I've not heard of results of the same setup in a C5. It's likely been done but kept secret, for now. We will soon find out how it turns out with my car. Paul is looking into calibrating the knock sensors. I've only found it for knock sensor #1.
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Here's some links of interest -
    Flat response Knock sensor (LS2)
    http://delphi.com/pdf/e/int_flat_knock.pdf
    Resonant type Knock sensor (LS1)
    http://delphi.com/pdf/e/int_broadband.pdf
    Excuse my ignorance, but why do people want to fit the LS1 sensors instead?.
    If you have an LS1 pcm the LS2 sensors won't work. If I have LS1 sensors and they work, why not?
    2003 red vert
    Mods:
    LPE 100mm MAF
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  1. No knock sensors???
    Last Post: July 9th, 2016, 07:28 AM
  2. Knock Sensors off
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: September 12th, 2009, 03:12 PM
  3. LS2 motor with LS1 knock sensors?
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: July 9th, 2006, 05:46 PM
  4. 98 knock sensors
    Last Post: June 10th, 2006, 10:12 AM
  5. LS1 knock sensors in C5 and LS2 block.
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 05:15 AM
