how does your fuel pressure hold up on wot at lower vs high rpm? do you have any logs with this stuff logged?Originally Posted by Doc
no i just have a gauge tapped in the fuel rail.
it drops to about 68psi under throttle, and idles at 70psi.
i imagine the lower value is probably the one i should use for
the IFR table.
No kidding, I started out with the Racetronix kit and then hooked up the Autometer gage and crapped my pants when I saw the first readings. My alternator (stock) was not up to the task of supporting my LC-1, N20 stuff. This lead to a bigger, better, more expensive alternator.Originally Posted by mr.prick
http://www.alternatorparts.com/Extre...144%20type.htm
Only catch with this puppy was the CS-144 case style. It fits no problem. The holes for the mounting hardware are another story. A really good friend, (screen name tunedportCJ5 on this board) helped me make a custom bracket to accomadate it.
www.efialchemy.com
www.greatamericancarwar.com
Sure, I am at work right now and I didn't bring my laptop today. Do you mean "How does FP hold up when going to WOT from low rpm VS. High?"Originally Posted by redhardsupra
Sorry, I've got a bunch of whiney Engineers crying right now.
www.efialchemy.com
yea, according to my calculations a walbro 255 should be running out of flow on higher rpm's, i wonder how visible it is, and also i wanna see if i could estimate the dynamic pressure, as the fp sensor only captures static one.
Will EFIlive check fuel rail pressure without special gauges?
Bill
2011 Camaro 2SS/RS L99 RJT
VMax Ported RJT Throttle Body
Gorilla Wheel Lock System;
Look in the tuning tool under Help> Tutorials>LS1 FP sending unitOriginally Posted by BowlingSS
Not that hard.
www.efialchemy.com
Thanks.Originally Posted by Doc
Bill
RHS,
I have several logs with fp data @ the rail and I'm using a 255. I've also got an Aeromotive fp regulator after the rails to try and control the fp, and if it makes a difference mine is also super charged.
Bill
72 K/5 4x4 Blazer, Radixed LQ4 with 3.2 pulley, WCCH 90mm TB, LPE GT2-3 cam, Stainless Works Headers, NV4500 5 speed, 14 bolt FF rear, Dana 60 front, 4.56 gears, detroit lockers, 4 wheel discs, Hydro brakes, full autometer gauges and more....
well what is your fuel pressure!Originally Posted by billyjo
