Just like the title say's. I am going to start the Auto VE tuning today and wanted to know if you all think it is a good idea or not. I seen in the LS1 tech that the guys have been removing the resistor because it tells the car less airflow is coming in, so that would increase timing. If I should remove the resistor what do you all recommend cutting it out or desoldering. Thanks.
