Ok I Need a pid Fix
We Are tring to tune a 05 C6 with a SD tune ...the problem is i need GM.AFR_B to work with the Base Efficiency numerator 1 for the tech edge not of just the GM.AFR ....PLEASE HELP!
Bill
The easiest way would be to go to the sae_generic.txt file and add '_B' to the GM.AFR info for the Tech Edge.
C:\Program Files\EFILive\V7\Configuration\sae_generic.txt
# Tech Edge WBO2
*CLC-00-916
V 0.0 5.0 .1 "{EXT.AD1}"
AFR 9.0 19.0 .1 "{EXT.AD1}*2+9"
*CLC-00-917
factor 0.0 2.0 .1 "{CALC.AFR_TE1.AFR}/{GM.AFR_B}"
*CLC-00-918
V 0.0 5.0 .1 "{EXT.AD2}"
AFR 9.0 19.0 .1 "{EXT.AD2}*2+9"
*CLC-00-919
factor 0.0 2.0 .1 "{CALC.AFR_TE2.AFR}/{GM.AFR_B}"
thank you thank you thank you....
Two Thumbs for you!!!!!!!!!! Thank you very much.
Also want to say thanks and two thumbs up for Jesse at wait4me.
EFILive has some of the BEST SOFTWARE SUPPORT I have ever seen in a company!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
