Originally Posted by
joecar
The PCM uses the IFR cell at MANVAC==0 to calculate IPW, and then IDC is calculated as SSpdDmon said in post #3.
Now, if you had a manifold referenced FPR, the IFR table would be flat (because the FPR now alters pressure such that pressure delta across any injector is constant as MAP varies)... is this your RR regulator...?
i.e. if you're installing a manifold referenced regulator (air hose connects manifold to FPR), you have to recalculate the IFR table based on the FPR pressure with the hose disconnected (i.e. at BARO)... and the IFR table would be flat horizontal all across.
