Results 1 to 4 of 4
Thread: Need help with at speed off throttle hunt
    Default Need help with at speed off throttle hunt
    The car:
    2000 T/A LS1
    224 / 224 588 588 112LS Cam
    LS6 heads ported
    long tubes
    3500RPM stall / 3.73 gears
    80mm TB
    granitelli 8xmm MAF
    LS6 intake
    more I am sure that I am not listing, but most likely not all that important.
    The car pulls a 12.8 @ 110 in the 1/4 (at 5800' above sea-level) and runs perfect except for one thing.
    When the car is being driven (yes also a daily driver) the RPM will fluctuate between 700 and 1050-ish when no load is on the car and it is coasting in gear. The slower the speed of the car (say 15MPH to 30MPH) the more it shows it's ugly head. The faster the car is traveling (approx 45-ish to above 50) it is not noticable or not even there. I have corrected just about everything airflow and overspeed/underspeed possible that I have in my notes and from Jeff (thanks dude!). I do not want to say what I have changed in order to get some fresh eyes on this issue.
    PLEASE post what you would have changed in your customer or personal setups to correct this. I will confirm if I have already done that or not. If what you suggest works I will post it up for sure.
    Thanks so much guys!!
    -Kenny
    Jun 2005
    Quote Originally Posted by KAZ MotorSports
    The car:
    2000 T/A LS1
    LS6 heads ported
    long tubes
    80mm TB
    granitelli 8xmm MAF
    LS6 intake
    -Kenny
    Kenny,
    You mind emailing me his tune? I'm curious to see what's what.
    Jeff,
    PM me your email address. I have it on the home office computer...not where I am now.
    Thanks,
    -Kenny
    Lifetime Member Doc's Avatar
    Oct 2005
    Sounds like there might be a descrepancy btw the spark tables; idle, High/Low at light load/ rpm values. MAP the spark and I think you'll find your bad actor(s).
    www.efialchemy.com
    www.greatamericancarwar.com
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. 5 speed BBL
    By Big Mike in forum Allison 5 & 6 Speed
    Last Post: April 27th, 2009, 03:49 PM
  3. 6 speed PID's
    By rcr1978 in forum Allison 5 & 6 Speed
    Last Post: August 16th, 2008, 02:32 PM
  4. 06 LLY with six speed ??
    By weazel132 in forum Duramax LLY
    Last Post: October 27th, 2006, 09:39 PM
  5. speed vs, rpm?
    By ytry in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 18th, 2006, 01:34 AM
