![Quote](images/misc/quote_icon.png)
Originally Posted by
ds8
These are the ones I am using:
OK DESCRIPTION CAPTION UNITS SYSTEM CH PARAMETER
Y Calculated Injector Flow Rate (Generic scan mode only) INJFLOW Grams/s,Lbs/Min Fuel 2 GM.INJFLOW
Y Calculated Load Value LOAD_PCT % Performance 1 SAE.LOAD_PCT
Y Cam Phase Angle Desired CAMPA_DES Degrees Conditions 2 GM.CAMPA_DES
Y Commanded Air Fuel Ratio B AFR_B :1 Fuel 1 GM.AFR_B
Y Damped VSS DAMPVSS KMH,MPH Performance 0 CALC.DAMPVSS
Y Delivered Engine Torque to Transmission TRQENG_B Nm,Ft-Lbs Transmission 2 GM.TRQENG_B
Y Engine Coolant Temperature ECT °C,°F Temperature 1 SAE.ECT
Y Engine RPM RPM RPM Conditions 2 SAE.RPM
Y Ignition Timing Advance for #1 Cylinder SPARKADV Degrees Spark 1 SAE.SPARKADV
Y Injector Pulse Width Injector 1 INJ1PW ms Fuel 2 GM.INJ1PW
Y Intake Air Temperature IAT °C,°F Temperature 1 SAE.IAT
Y Intake Manifold Absolute Pressure MAP kPa,inHg Air 1 SAE.MAP
Y Last Shift Time SHIFTLAST Seconds Transmission 1 GM.SHIFTLAST
Y Long Term Fuel Trim - Bank 1 LONGFT1 % Fuel 1 SAE.LONGFT1
Y Retard Due to Knock KR Degrees Spark 1 GM.KR
Y Short Term Fuel Trim - Bank 1 SHRTFT1 % Fuel 1 SAE.SHRTFT1
Y Throttle Position TP % Throttle 1 GM.TP
Y Transmission Fluid Temperature TFT °C,°F Temperature 1 GM.TFT
Y Vehicle Speed Sensor VSS KMH,MPH Conditions 1 SAE.VSS
