I have a 99 camaro ls1 auto trans with a 6 psi powerdyne supercharger. I have migrated to a 2002 op system then upgraded to cos3, the engine is totally stock with a magnaflow cat back exhaust. My wideband is on order for the fuel tune I will use VE auto tune to dial that in. Stock map sensor for now as I don't have time to pull the intake to replace the map sensor to do a 2 bar setup. I got the car running fairly decent as long as you don't get into heavy boost. I experience detonation when in boost, I know that the spark needs to be retarded but I don't know which table to retard and how much. I also get kr up to 3.3 during low load, low speed acceleration. Can someone be kind enough to give me an idea of what to do here or maybe show what a tune should look like. As you can probably tell I have only been doing this a few weeks and have already learned a lot but I would love to be able to feel the power without fear of destroying my engine.
