Results 11 to 20 of 30
Thread: 04 truck Efan problem using pins 33 and 42
  1. #11
    Jan 2007
    Quote Originally Posted by kbbrett
    Actually, if pin 33 is good, that should be all I need. Thanks.
    That is what I am trying to tell you Pin 33 on 99-02 is not the same asn 03+. I believe it is used for something completely different. At least this is what I have been told.
  2. #12
    Jan 2007
    It looks to me like C1 42 is not used on an '02 truck. C2 33 is blend door.
  3. #13
    Feb 2006
    Kbbrett you are correct. The Blue connector C1 terminal 42 is not used on the 2002 truck. On the Red connector C2 terminal 33, that circuit is used to control the recirculation door for the A/C. If you have the automatic climate control, this circuit is not used directly by the PCM. For vehicles with manual A/C controls the PCM will force recirculation mode if the high pressure gets out of range. The user control of the recirculation door will still be functional. In either case the switch at "G0106" needs to be changed to fan #2 control to allow PCM control of both fans.
    The primary fan control is at C1-42 and secondary fan control is at C2-33. If using only one fan, use the primary circuit.
    Al
  4. #14
    Oct 2006
    Part of the problem people will buy a Nelson Harness which is not made for the 05 34" fans (LS1 27") and try to use it , he needs to add a another trigger wire and re-configure the relays .
    And another bad thing is most people will do a harness for the larger fans (05 34") and not add any protection (fuses 40 amp min) , oh well .
    Bottom view
    Factory harness and will work for most trucks .
    Went up a few dollars now close to 2 , part #15216042 .
    See the fuses and large relays , what you need for the larger fans .
    2006 Trailblazer
  5. #15
    Feb 2006
    I would recommend the three relay setup if you are planning on using dual fans. For low speed, both fans run at low speed in series. On high speed, both fans run with full voltage in parallel.
    AL
  6. #16
    Oct 2006
    Factory Diagram :
    Yours is close .
    2006 Trailblazer
  7. #17
    Jan 2006
    I built my own harness. Made an EXACT copy of the GM harness. Im not paying $200+ for a harness I need that comes with a harness I dont. Im into my harness a whole $40 bucks and some time. And it works the same way as the GM unit.
    -Jared
    EFILive-Dynatech-Corsa-AEM
  8. #18
    Oct 2006
    Quote Originally Posted by 99Silver6.0
    $40.00 not bad , I got the factory harness when they were 108 to the door .
    They must have caught on to what people were doing and raised the price .
    Can you give a link to the relays and fuses you used ?
    2006 Trailblazer
  9. #19
    Jan 2006
    Id link ya to the relays but I got them local. I didnt skimp it ont he relays. I got 3 70amp Cole Hersee SPDT relays at $8 a pop.
    Sockets same deal, got them local. They look kinda like these though. http://www.partsexpress.com/pe/showd...number=330-075
    Fuse block isnt sealed but I chose it for the heavy wiring it had. Has HUGE power wires on it. $15
    But all in all worked well. I hid all of it right under the main fuse panel. Had to remove the big plastic cover that snaps off. Ill get some pics tomorrow.
    On a side note, you will need 2 PCM pins!!
    -Jared
  10. #20
    Oct 2006
    Wow 70 amp Single Pole Double Throw (SPDT) relays , should last .
    The fuse block , where did you get that at ?
    Pics would be nice .
    When I made one I used these : http://www.alliedelec.com/Search/Pro...CCCE003BA7E17F
    They worked real nice because you can link them together .
    PCM pins , someone else has posted this link but here it is again http://www.eficonnection.com/eficonnection/100w.aspx
    Thanks for the info .
    2006 Trailblazer
  1. 07 trailblazer ss efan
    By nchristian in forum E37, E38 & E67 PFI ECM's
    Last Post: November 21st, 2009, 12:00 AM
  2. Pins for PCM
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: August 28th, 2009, 06:49 AM
  3. 6.0 L Truck engine fan control pins
    By JohnL in forum Gen IV V8 Specific
    Last Post: September 4th, 2007, 12:33 AM
  4. Finally have the truck back... New COS #3, one problem
    By turboberserker in forum Custom Operating Systems
    Last Post: January 27th, 2006, 04:32 PM
