Results 1 to 3 of 3
Thread: Won't Connect to get codes
    Jan 2005
    Default Won't Connect to get codes
    I've been trying to connect to my wife's 04 V6 Envoy and it won't recognize the pcm. All I'm trying to do is read codes. Getting very frustrated. Tried Autotap and old cable, tried V5, V6, and V7 with EFI Live V1 cable and it won't show me any codes. When I hook it up to my new 07 GMC Sierra it won't do anything either. Granted it has been a couple of years since I tried to use these programs but I spent hours today just trying to connect and I've never had these problems trying to scan a vehicle. When I connected autotap to my corvette, it started reading the pcm right away. Any help greatly appreciated.
    Nick
    07 Z06 2LZ LMB: Custom Grind Cam (231/247 114+3 653/660 LSL Lobes), American Racing Headers, Ported LS7 Intake, Halltech Killer Bee.
    07 GMC Sierra: Borla, S&B Cold Air
    Gone but not forgotten:
    EB Z06 Vette: Borla, Halltech Stinger, Long tubes
    2002 WS6 Stage 2 LS6 Heads, Cam, Longtubes, Etc.
    1997 Z28 Heads, Cam, Stall, Long Tubes, Etc.
    1994 Z28 Boltons
    OK man, here is your problem. It is an LL8 aka I6 using the P10 controller. Im guessing you are trying to use a Vx controller not the LL8 Inline 6 controller. Use V1, nothing else prior will work. That should work.
    Jan 2005
    Thanks for the response. I am actually using the inline 6 controller and it still won't connect. It actually says that it's ready but all of the buttons are still grayed out so I can't use them. Doesn't make sense it should atleast let me pull codes with ATap. I wonder if the older versions of EFI live are conflicting with the newer versions.
  1. can not connect
    By Jetmech in forum General (Diesel)
    Last Post: November 29th, 2010, 08:31 AM
  2. Can't connect to RR fix
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 26th, 2009, 12:31 PM
  3. V1 won't connect
    By chrisr in forum FlashScan V1
    Last Post: August 24th, 2008, 11:08 PM
  4. cant connect
    By mickkk in forum Duramax LLY
    Last Post: December 21st, 2006, 09:40 AM
  5. HELP: Can't Connect
    By tdzee in forum Tips and tricks
    Last Post: May 26th, 2005, 12:40 PM
