Results 1 to 4 of 4
Thread: Scan Tool won't monitor or record
    Aug 2007
    Question Scan Tool won't monitor or record
    Well folks, it has been a long afternoon and evening getting acquainted with my new software. I have been successful at reading and storing the stock tune from my vehicle, but it the scan program locks-up (not-responding) when i go to monitor or record data.
    The software version is EFILive_Scan V7.4.2.exe Build(534), Flash Scan V2. Trying to read data from my 2001 GMC Sierra w/ 5.3. The program will connect (green button top left) to the pcm, but thats it. Are there any other items I missed in the update download section? Anyone else have a similar issue to this? Any thoughts are appreciated. Thanks!
    Chris
    Chris, welcome to the forum...
    Check these things in the scan tool:
    - enter your VIN/OS (File->Enter VIN);
    - enter your controller (File->Select Controller);
    - pids are selected (F8 tab);
    - dashboards (F10 tab, A, B, C) must have gauges/charts for those pids;
    - press red button (bottom center);
    View the Data F9 tab to see if the values are updating (e.g. RPM);
    If all of the above are set, try changing the scan mode (Edit->Properties->Logging->Scan Mode) and try again.
    Aug 2007
    Thumbs up Viola!
    Joecar,
    Thanks for the help, I tried all of those things but it seems to have been my USB port not properly communicating with my Flash Scan V2 . I reinstalled the flash scan drivers and tried a different USB port, restarted my laptop, and like magic it worked. Thanks again, I have attached my first scan for your viewing pleasure.
    I think that I am going to do a second scan with the correct PID's logged for the transmission, according to your transmission tuning sticky. From the looks of it I believe I should start out trying to tune the appropriate items in the trans first. In the next week or two I am installing an entirely new exhaust: headers, cats (stock cats are shot, keep throwing cat inefficiency DTC's), custom 2.5" y-pipe to 3" mandrel bent exhaust, through a 3" Hooker Aerochamber, and out the right rear corner.
    Cool...
    In the next week I'm removing headers so I can pass visual...
  1. Tuning tool not following scan tool (VE table)
    By dvx in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2008, 09:43 AM
  2. Scan tool match tune tool?
    By zapp168 in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 05:27 AM
  3. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  4. Fit to Scan Tool/Tune Tool
    By limited cv8r in forum General
    Last Post: March 3rd, 2007, 06:10 AM
