Results 1 to 7 of 7
Thread: Does any body have a OS 2000 to 2002
    Senior Member RandyWS6's Avatar
    Jan 2005
    Default Does any body have a OS 2000 to 2002
    I have tryed and tryed to switch over from OS-09381344 to OS-12212156 and every time i do i get a flashing SES light but no codes ive tryed four differant times and get the same thing.And i have a custom tune for my LS2 418cid. This for a 2000 WS6 TransAm M6
    stock tune_0001 factory tune.tun
    main tune _418cid. #2 nos installed.tun
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
    Feb 2006
    Yep,
    Bear with me while I dig a copy out for you.
    Jim
    Feb 2006
    Here you go, it's COS 3 (came from 9381344 then to 12212156 then to 02020003 (COS3)). Careful as it's in SD mode set up for mine (obviously), (LS1, TR230 Cam).
    Rgds
    Jim
    Jun 2005
    Here's the one I have.
    2000 A4 f-body file.
    Jan 2005
    Thanks, ill try it.
    Jun 2005
    Quote Originally Posted by RandyWS6
    Thanks, ill try it.
    Keep in mind a flashing SES light usually means misfires were detected. On cam'd applications, the misfire tables can be too touchy and may require some adjustment. For my car, I just increased them (C5622, C5623, etc.) 200% across the board.
    Jan 2005
    I have a custom tune with the misfire codes removed for a long time and never had any code with the tune that i have with my custom 2000 OS 09381344, When i installed the 2001+ OS 12212156 and change all my 2000 OS over is when i get the SES (Flashing light) and that's only when at cruse or WOT but not a idle. And when i scan the codes there not any!!! Its all most like a ghost light.
  1. 2002 F-Body missfire during AutoVe
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: May 31st, 2010, 02:23 AM
  2. Convert 2000 F-Body OS to a Flex Fuel OS?
    By coctostan in forum General (Petrol, Gas, Ethanol)
    Last Post: September 23rd, 2009, 04:46 AM
  3. body control module on v6 2002 camaro
    By Aint Skeered in forum EFILive V6
    Last Post: July 16th, 2008, 12:12 AM
  4. Going from 2000 to 2002 OS problem ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: June 9th, 2007, 10:00 AM
  5. I have a 2000 F-Body; should I change to a 2001 or 2002 OS?
    By leres in forum General (Petrol, Gas, Ethanol)
    Last Post: August 26th, 2005, 05:44 AM
