Results 1 to 10 of 12
Thread: what is normal operating ect?
    May 2007
    Default what is normal operating ect?
    i went for a little drive for the first time to do some data loggin and realized that my ect average is 214 f.
    ut went as high as 217 f . is this about right? i have a 160 termostat also.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    May 2007
    this is in the trans am by the way
    2000 NBM trans am.
    Jun 2005
    It depends on the weather and what your fans are set at.
    I see 180~190*F (A/C off) while cruising around. But, we don't usually see more than 85~90*F days here in MI and my fan on/off temps have been dropped 40*F from stock.
    The fact that you have a 160*F stat only means your stat opens at 160*F. It's not going to make the engine run cooler. It will allow it to run cooler under the appropriate conditions. But, it won't make it...
    While observing ECT, use bidirectional mode in the scantool to turn fans on at high speed...
    if after a few minutes ECT starts to drop closer to thermostat temp (+5~10 degrees), then everything's fine, you just need to adjust your fan temps...
    otherwise if ECT doesn't drop you have an airflow and/or cooling system problem.
    May 2007
    I have not scanned it with the snap on yet but it always showed avg temp to be around 187 in my car. this is the first time I ever scanned the t/a with the efi live .
    fan temps should not play to much of a part when cruising on the interstate at 70 mph . the airflow should be sufficient with the cruising speed. it still held 214 on a 5 mile 70 mph trip.
    2000 NBM trans am.
    May 2007
    when I get to my laptop I am going to try to post what I data logged to let you all look at it and see what I was reading.
    2000 NBM trans am.
    Quote Originally Posted by Aint Skeered
    This indicates a problem... with your TS you should have seen something like 170-175.
    (I assume you weren't pulling a big load up a steep hill for 5 miles... )
    Jan 2005
    you might check under the nose to make sure you haven't picked up a walmart bag or other debris that would block air flow.
    FWIW, my bird run's 190-192 *F AC on or off
    Mine runs at 196 with AC on or off.
    May 2007
    H]2021[/ATTACH]
    here is the file. let me know what all you see going on. I posted this tune before and was told to start over as it has a lot to be desired but I dont have a wide band yet so it has to wait till i get one. I drove slow all the way up to the 1650 to 1750 frame where i made a little hit.
    2000 NBM trans am.
  1. Isthis Normal?
    By Yortt in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 23rd, 2008, 12:14 AM
  2. IAC issue or this is normal?
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 12th, 2007, 05:34 PM
  3. VE Table >100% normal?
    Last Post: December 8th, 2006, 07:38 AM
  4. Is this normal for VE tuning
    By 98SS2836 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2006, 10:24 AM
  5. Please Clarify HOT and NORMAL
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: March 8th, 2005, 09:32 AM
