Results 1 to 4 of 4
Thread: 2004 monaro/gto o2 harness connector
    May 2007
    Default 2004 monaro/gto o2 harness connector
    Does anyone know the part number or a like for like replacement that is suitable for the narrrow band 02 sensor connector for an 04 year monaro/gto (5.7).
    Unlike the newer cars with the square connector mine ahs the older flat four wire connector, much like on a PC's IDE power supply.
    Everything is wired in but I just want to fabricate a nice clean extention loom and rather than pay $100 dollars for a kit here in the uk I'd like to fabricate one!
    I do actually have a spare connector from the old sensor but I cannot get the pins out - which leads to my 2nd question.... how can I get the pins out so I can fabricate my new loom with the spare connector?!
    If it's a Metri-Pack connector, you can pull out the pin terminals using this pick tool:
    http://www.ledfoote.com/osc/product_...87dd60af0e056b
    May 2007
    a paper clip bent out and filed flat on one side works well too, you just have to "jiggle" it a lot
    Ed
    May 2007
    cheers guys!
  1. Where to buy connector?
    By PRAY in forum General (Petrol, Gas, Ethanol)
    Last Post: December 6th, 2007, 03:19 PM
  2. 2004 Monaro PCM
    By stigmundfreud in forum Custom Operating Systems
    Last Post: July 9th, 2007, 10:41 PM
  3. 2004 gto pcm connector colors...
    By brokenfly in forum Custom Operating Systems
    Last Post: May 29th, 2007, 02:06 PM
