Results 1 to 6 of 6
Thread: Custom OS
    Feb 2007
    Default Custom OS
    I noticed my OS number doesnt match any of those in the Pdf upgrading OS tutorials from Efilive (Just looking for now, I want to get a twin screw, later on)
    Os = 12596734
    Calibration = 12596733 version = 7.20
    Os id = AA
    Bcc = YKWB
    Andy
    Andy, welcome to the forum...
    If your current OS number doesn't match any listed, then you have to "migrate" to one of the ones listed.
    What year/model car do you have...?
    Andy, what year / model have you got there?
    Feb 2007
    Thanks for the welcome, its a 2005 Monaro VXR (Vauxhall) E40 PCM
    World Manufacturer Index 6G1 General Motors Chevrolet - Australia
    Year of manufacture 5 2005
    Model Z VZ Series
    Engine U Gen-IV LS2
    Engine size U 6.0 litre V8
    Body 1 Coupe
    Luxury X Calais
    Restraints 4 Manual Belts With driver & passenger & side inflatable restraints
    Plant L Adelaide (Elizabeth)
    Sequence 398201 398201
    Also after reading the PCM calibration I get a fault U0121, communication lost with the traction control module. Is this normal or do i have a real fault?
    I forgot, on the E40 when you load a stock OS up there will be a new tab "Upgrade OS". Open that, click on the Apply Upgrade button, full flash and you are good to go.
    Sometimes DTC's do come up after reading or programming, however, EFILive should be clearing them automatically. Are you able to manually clear that code?
    Feb 2007
    Quote Originally Posted by GMPX
    I'll try to clear the code.
    Yes Ive seen that option, can you choice which custom OS to upgrade to?
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
