Results 1 to 10 of 15
Thread: Injector Duty Cycle??
    Aug 2007
    Default Injector Duty Cycle??
    First off, i am a newbie and just starting to understand all this so bare with me.
    I selected the PIDs that I want to monitor but for some reason, I do not have the option of monitor fuel injector duty cycle.
    Car is a 2005 C6 A4
    Thanks,
    Patrick
    Patrick, welcome to the forum...
    On the pids tab:
    1. uncheck the Supported box;
    2. click twice on the column heading "Parameters" to sort on that column;
    3. look down that column for CALC.INJDC1 and CALC.INJDC2;
    4. select these (they don't occupy any channels so you're not exceeding 24 channels/frame).
    (If you use 24 or less channels, then logging rate per pid will be 10 times/sec...
    if you exceed 24 channels, then logging rate per pid will be less).
    (note: the CALC.INJnDC pids are not for your vehicle)
    Aug 2007
    I did exactly what you suggested but when I go to "connect" I am prompted with a message stating some PIDs are not supported....would you like to continue?
    Try this: right click on each of those 2 pids to see which other pids they depend on, and select these other pids.
    Jun 2007
    You may need the latest version download make sure you have the latest updates. then the idc should automatically come up when you select the e40 controller.
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
    Aug 2007
    I just purchased my V2 a couple of days ago. Will i already need to download a newer version?
    Nov 2006
    Quote Originally Posted by Ponch
    yes
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Did you connect to the vehicle and go to 'Info' in the Scan Tool and validate PIDS (Shift+F2)?
    Jun 2007
    When I got mine it wasn't the newest version.
    Guys, unfortunately you can't always be assured you are getting the latest hot out of the oven package. Keep in mind many of our resellers keep stock on the shelf. Does this mean you are getting some old dusty unit?, not really, it's no different to buying a new DVD player, it might have been built 3 months prior to hitting the shelves.
  1. Injector Duty Cycle.
    By ssdungeon in forum Gen III V8 Specific
    Last Post: September 10th, 2009, 05:50 AM
  2. injector duty cycle
    By minytrker in forum General
    Last Post: September 10th, 2009, 05:24 AM
  3. Injector duty cycle above 100%
    By ls1vt209 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2008, 04:37 AM
  4. Injector duty cycle..
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 26th, 2008, 07:21 AM
  5. Injector PW & Duty Cycle
    Last Post: June 15th, 2008, 04:39 PM
