Results 1 to 10 of 17
Thread: Stock 2.2l 98 S-10
    Default Stock 2.2l 98 S-10
    Since were still waiting on calibration files, if anyone has a stock calibration from a 98 S-10 2.2l that did not have an EGR please post for me. I need to delete the EGR on one and would like to just flash the factory file from one that did not come with it. I know that some in 98 and 99 at least did not have EGR. Thanks,
    Aaron L.
    Conover, NC
    Aug 2004
    If you email me the tune file, i will send you a calibration file to put in so you can edit it yourself.
    Quote Originally Posted by wait4me
    Thanks,
    I think I sent you a couple a week back, I'll resend them. What email should I be using? Thanks,
    Aaron L.
    Conover, NC
    Aug 2004
    File sent.
    Thanks,
    Got another one for you too if you've got the time. I'll send another email.
    Thanks again,
    Aaron L.
    Conover, NC
    I tried to flash truck and got bootloader failed. Tried in slow mode and same thing. Test fails the same way. I'm not sure what's going on but the PCM will read just fine. Any ideas?
    Aaron L.
    Conover, NC
    Aug 2004
    Last time i saw that, i just had to pull a radio fuse and it worked perfectly.
    Dec 2006
    So does that mean that we can flash a vehicle even if after the read it says "Unrecognised PCM"?
    '01 Z28 LS1 / T56
    7.59 @ 94.45 (1/8 mile)
    YouTube channel
    '02 C1500 L59 / 4L60E
    8.24 @ 85.08 (1/8 mile)
    www.lsxnos.com
    Aug 2004
    if you can read it, you can write to it. But efilivetune will need to have an operating system put into the calibrations folder first before it will let you flash it back in. That error just means that you dont have the os system yet.
    Member JST's Avatar
    Jul 2007
    Quote Originally Posted by trudynosports View Post
    x2 reject the bootloader
  1. GETTING some HP from a stock Gen-IV V8
    By A.O.A in forum Gen IV V8 Specific
    Last Post: June 7th, 2009, 07:57 PM
  2. Stock Bin
    By teddyls1 in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 04:03 AM
  3. RR and stock PCM
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 11th, 2006, 06:21 AM
  4. Need stock .bin
    Last Post: September 5th, 2006, 07:25 AM
  5. Is this a stock 02 ZO6 cal?
    Last Post: August 15th, 2006, 11:41 PM
