Results 1 to 6 of 6
Thread: valet mode
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    Question valet mode
    In order to use the valet mode on the DSP5 OS, must the DSP2 switch be wired to the signal and the ground in the ECM?
    Nick
    May 2006
    I have also wondered if you could use any ground source available to you or, must it be the one on the ECM listed in the documentation.
    When I wired mine, I did it just like the print says because I didn’t wont to take the micro-pack plug back apart and run more wire if it didn’t work.
    2001 K2500HD Duramax/Allison
    Senior Member lakingslayer's Avatar
    Dec 2005
    It is recommended to wire it to the ECM ground. This is what the the ECM signals are based on. If you use another ground it may have a different potential than the ECM ground.
    Now it probably will work not using the ECM ground depending on the quality of the ground you use. Mine does.
    Apr 2007
    hmmm, I was thinking along simlar lines. Guys not using the ECM ground seem to be having trouble. Just curious if this solved it for anybody.
    Thanks Kingslayer
    By using the ECM ground you are ensuring the pin is grounded to the same potential the ECM is at. I don't know the exact switching threshold on the ECM inputs, but, if you connect to a ground with a different potential it might not switch the pin low enough to trigger the input to change state.
    Apr 2007
    Thanks Ross, I appreciate the help.
    Nick
  1. E40 Valet mode?
    By ringram in forum Custom Operating Systems
    Last Post: April 27th, 2007, 10:21 PM
  2. Valet Mode
    By ZL1Killa in forum Custom Operating Systems
    Last Post: April 10th, 2006, 01:08 AM
  3. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
