Results 1 to 5 of 5
Thread: Those pesky SVO 30# injectors
    Jun 2005
    Default Those pesky SVO 30# injectors
    So, I think I've figured some stuff out. I've always asked people for hints when it comes to tuning for injectors. But, never got any solid answers. Well....here's what I did to help my situation out.
    First, the symptoms:
    The problem I was having with my setup was no matter what, it seemed I was having a rich decel issue. AFR's always seemed to be in the mid to low 13's. I would drop the MAF/VE or increase the IFR and still....rich decel.
    Some background on the tune I'm working with:
    My IFR table was reverse-engineered using a stock MAF curve. By setting my B0120 to 1rpm, I found the best line that worked so that my desired AFR matched my actual AFR on the WB. If you decide to use a spreadsheet to calculate your IFR table like most do, the following should still help.
    B3701 (IPW Voltage Adjustment) - I have read in several locations the fact that the SVO30's have about a 30% greater offset than our stockers. So, I increased the stock table 30%. I then flattened the table out so that the values for the 80kPa row and the 0kPa row were equal by using a value somewhere in the middle.
    B4001 (IFR) - See above and picture below.
    B4003 / B4004 (Min. IPW) - I wanted to make sure the PCM would allow a small injector pulse width. So, I dropped both of these two tables to 1.0 across the board.
    B4005 (Small Pulse Adjust) - I zero'd this table out for starters. This table and the B3701 table are added on to the desired pulse width. One too many roosters in the hen house for me. This table seems to be useful if you need to make pulse width adjustments based on injector on-time. I haven't got that far to notice a need. If you leave DFCO active later on, you probably shouldn't zero out the samller cells. The injectors don't cut all the way off during DFCO. I believe their pulse width during DFCO is determined by this table. Still have to look into this further.
    Once I made the above changes, I logged my GM.IBPW1, GM.MANVAC, GM.VOLTS and BEN pids. The GM.IBPW1 pid shows the final commanded injector on time. During decel, it would bottom out in the low 1.80~1.82ms range. AFR's were still in the 13's. Based on the GM.MANVAC and GM.VOLTS pids, I could see where that put me in B3701. So, now I have a table to change, I know how long the final pulse width is, and I know what my AFR is. Since my AFR was low 13's and commanded was stoich, I knew my error was about 10%. With an IPW of 1.8, I found a 10% decrease would mean a new IPW of 1.62 for that MANVAC vs. VOLT cell (1.8*0.9=1.62). In my case, that's the 13.5V cell and the 75kPa row. The value in my B3701 table was .577ms after the changes from above. I needed to reduce it 0.18ms (1.8-1.62=0.18ms). That essentially is a 31% reduction to the value already in the cell (0.397/0.577=0.69). So, I highlighted the entire row and reduced it by 31% effectively shortening the pulse width. I had to do the same procedure to the 80kPa row as well.
    The picture below is what is currently in my tune. Decel AFRs are no longer rich. It'll take a little more fine tweaking. But, it's close for now.
ID:	2029   Click image for larger version.
    Lifetime Member Chalky's Avatar
    Sep 2003
    Keep us posted.
    When do you sleep?
    Would this scenario work with IFR's for the SVO 30's?
    Jeff: Duh, just noticed in your post that you are still running the SVO 30's. I thought you had gone back to a 26 or 28 GM.
    2015 Z06 A8
    Jul 2005
    and why would you assume your MAF calibration is perfect? is your lid/intake/MAF/bellows perfectly stock?
    Jun 2005
    Quote Originally Posted by Chalky
    Keep us posted.
    When do you sleep?
    Sleep? What's that?
    Quote Originally Posted by redhardsupra
    I was just explaining how I got that IFR table setup that way....not saying it was right, wrong, or indifferent. The main focus on the problem at hand has to do with zero-ing out the small pulse adjust and working with the IPW Voltage Correction table. Like I mentioned - if you're using a calculated IFR table, it should work just the same.
    Aug 2007
    i was rich on decel also with my 42lb-drs, b4003,4 fixed it, reduced the values by 5%.i didn't touch b3701 though and b4001 is set at 65% above the 28lb-drs values.
  1. Injectors
    By ls1vt209 in forum Gen III V8 Specific
    Last Post: September 4th, 2008, 01:38 PM
  2. 96 lb/hr injectors
    By thosewhohatedmecreatedme in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 04:57 AM
  3. Injectors...
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2006, 03:11 AM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
  5. Pesky Trouble Code
    By mistermike in forum General
    Last Post: August 13th, 2005, 03:07 PM
