Results 1 to 4 of 4
Thread: SD tuning problem
    Oct 2006
    Default SD tuning problem
    I've got an 06' Trailblazer SS (LS2/t42). I was commanding the engine to run mafless so i could do some tuning to the ve table and was having a problem with every time I pull the plug on the maf(I use a breakout harness to seperate the IAT) the tranny will divert to full line pressure and shift extreamly hard. What tables is the LS2 and t42 combo. using to adjust maf to pressure modulator blending? I went through every table again and i'm sure i'll be banging my head on the wall when somebody lets me know. any help would be apriaciated. thanks
    Ah, it's not a table as such, send your tranny tun file to support and I'll fix it up for you. The culprit is not in the current release software.
    Oct 2006
    so what is the problem (now you got me curious)? I'll send the file tonight when i get home from work
    thanks ross
    Oct 2006
    e-mail sent. thanks again
  1. QUICK!!! Tried Auto VE tuning and now I have a problem
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 1st, 2009, 09:28 AM
  2. Tuning around a mechanical problem.
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: August 20th, 2009, 10:26 PM
  3. tcm tuning problem
    By MAXXEDOUT in forum Allison 5 & 6 Speed
    Last Post: May 5th, 2009, 03:10 PM
  4. Odd tuning problem.. HELP!
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2007, 01:06 PM
  5. Efi Live Tuning Problem,, Need Help
    By Boll Curlee in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2006, 06:43 AM
