Results 1 to 10 of 11
Thread: CAL file format
    Aug 2007
    Default CAL file format
    Does anyone know exactly what the file format is of a CAL file? Is that binary or encrypted?
    Aug 2005
    Quote Originally Posted by runrun
    It's an efilive proprietary format, presumably defining the file structure of the particular OS in question.
    Aug 2007
    So there's no other way to navigate the data than to use the app? Hrm.
    Oct 2004
    I think I just replied to your email... They are binary and are more than likely encrypted. They are EFILive intellectual property and will not be made available outside of the EFILive applications.
    Andrew
    EFILive Crew
    Aug 2007
    Ah well, thanks for the info. Someone on an online job board (http://www.scriptlance.com/projects/1188217090.shtml) was looking for a developer to parse the files. I guess it actually sounds like they're looking for someone to hack them.
    Thanks runrun, looks like they forgot to read the EULA.
    Dumb part is they list the posters details -
    Username: arico100
    Company: AMSCORP
    Jul 2003
    Default this may very well be the stupidest man on the face of the earth...
    Here's more for you ....
    http://www.dieselplace.com/forum/member.php?u=12239
    Go get 'em.
    You can get an HTML listing of the calibrations, use File->Export Calibration List.
    You can add your own calibrations that you want to edit using the *.cal extension file format: *.cax
    It is currently undocumented but it will be fully documented and publicly available in the EFILive V8 release.
    But if you have the required information and a real need to add your own calibrations, contact me at paul@efilive.com.
    Meanwhile, reverse engineering the EFILive software and/or configuration files is prohibited by the End User License Agreement, here:
    http://www.efilive.com/eula.aspx
    You must not modify, reverse engineer, decrypt or decompile the EFILive software or configuration files, or any part of them. You must not use or allow any other party to use the EFILive Software and/or the configuration files (or any part of them) to reverse engineer, recreate, or otherwise replicate in anyway any of the information within or generated by the EFILive Software and/or the configuration files (or any part of them), or any of the attributes of the EFILive Software and/or the configuration files (or any part of them).
    Quote Originally Posted by View Profile: ARICO100
    Now can you give us a little background on yourself?
    Ran a hospital for 10 yrs. Left that to be a Contractor, and been dabbling in information consulting and inventing products.
    Yep, looks like he's been in automotive for years and years.
    Quote Originally Posted by beyerch
    Go get 'em.
    beyerch as in Charles?
  1. how to put tunes into dsp format
    By Chkmeout08 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 31st, 2010, 11:10 AM
  2. New DVD format
    By Chevy366 in forum Lounge
    Last Post: October 26th, 2009, 05:44 PM
  3. Unknown bin file format.
    By serpa4 in forum General (Diesel)
    Last Post: July 5th, 2007, 06:01 PM
  4. EfiLive file format question...............
    By FreddyG in forum Gen III V8 Specific
    Last Post: January 4th, 2007, 11:29 AM
  5. 97 PCM "Bad bin file format"?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2005, 12:13 AM
