Results 1 to 2 of 2
Thread: Which maf fail numbers are you using for C2907 and C2908?
    Default Which maf fail numbers are you using for C2907 and C2908?
    I had a problem with my car not starting with a known tune when I used 400rpm for C2907 and 2.0 seconds for C2908.
    When I changed C2907 to 300rpm and C2908 to 0 seconds the starting problem is gone.....
    You could hear a stumble with the 2.0 when it forced SD mode and sometimes would run for 2 seconds and die.
    What are y'all using?
    Guess I'll end this thread..... 2.0 seconds was too much delay for forcing sd for me....much easier to set it at 0 and force it during the crank at 300rpm, then it's in sd when the engine fires.
  1. If you fail to plan, you plan to fail!!
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2009, 07:02 AM
  2. PCM part numbers
    By killerbee in forum General (Diesel)
    Last Post: April 9th, 2009, 07:32 AM
  3. LC1 AFR output numbers
    By 1bar in forum General
    Last Post: March 23rd, 2009, 10:31 AM
  4. FTC Numbers
    By white2000ta in forum General
    Last Post: January 8th, 2008, 05:19 AM
  5. I cant get the"MAF freq Fail 1"parameter to = 0
    By SmaknSS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 2nd, 2005, 05:29 AM
