I have installed my two LC1's, I wired all my earths to one point (battery) like the manual said, wired the simulated NB lead to the NB plug and picked up the switched 12+ there also. Everything works except as I suspected the PCM has thrown 4 DTC's for the heater circuit voltag/performance of the two front O2 sensors.
Can I trick the PCM by wiring a resistor between the Heater+ and Heater- at the NB plug?
I should be able to determine its value by measuring the resitance between the two leads on the O2 sensor heater wires?
Apart from that everythings working, reading AFR's from both banks and engines running fine.
