Results 1 to 7 of 7
Thread: V2 not reading AD signal
    Aug 2007
    Default V2 not reading AD signal
    I just received my V2 a couple of weeks ago along with LM1 wideband. After spending hours trying to trouble shoot with AD calibrating and measuring output/input with a volt meter I finally checked the V2 and sure enough its not registering the raw data coming from the Wideband.
    Is there a fix for this?
    Ponch,
    Did you connect as follows:
    ADn+ = positive side of voltage trying to measure
    ADn- = negative side or common ground
    where n is one of 1,2,3,4.
    You can do a quick check of the A/D inputs by selecting the FlashScan options: F4->F4->F4 which will display the voltages form all 4 A/D inputs on the FlashScan screen.
    Then connect a 1.5V battery to any pair of +/- A/D inputs and see if the voltage is registered.
    Aug 2007
    Joecar...it is hooked up correctly.
    Blacky...I did all that already and the readings are stuck on 1. It doesnt change values even when i disconnect the power source.
    Ponch,
    Which V2 firmware version are you running...?
    Joe
    Aug 2007
    i just downloaded the newest update last week.
    Quote Originally Posted by Ponch
    It sounds like one or all of the A/Ds have failed. You should return it to the place of purchase for warranty/repair.
  1. ECM to ABS speed signal
    By THEFERMANATOR in forum Duramax LB7
    Last Post: June 28th, 2009, 04:23 PM
  2. A/C request signal
    By burtoncr in forum Gen IV V8 Specific
    Last Post: June 3rd, 2008, 07:37 AM
  3. MAF Signal
    By Spindoctor in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:23 PM
  4. torque`signal
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 6th, 2006, 03:26 PM
  5. How do I get the IAT signal to the PCM
    By mtnman in forum General
    Last Post: October 9th, 2005, 08:11 AM
