Results 1 to 7 of 7
Thread: Idle hangs for a few seconds when coming to a stop
    Mar 2004
    Default Idle hangs for a few seconds when coming to a stop
    I went through a complete rework of the 02 OS and 00 tune and the results are good but I have this annoying idle hang for a few seconds after I come to a stop which I suspect is also making it slow to decelerate. If I change the TC and TF airflow and or decay it's better but still hangs when I come to a stop and slow to decelerate. It hangs by about 100 rpms. I didn't have it when I was running the 02 settings so I just think I'm missing something. I went through the idle tutorial but don't see anyhting that causes this? Thoughts?
    2000 Camaro SS Convertible
    M6,
    LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
    Jun 2005
    Double check ALL of the TC and TF settings to ensure they're equal to the old tune. TF Multiplier=1, TC MPH on/off, etc. The easiest thing to do is to log them. Log the IACDES_B, Throttle Cracker and Throttle Follower. You'll see where it's coming from.
    Mar 2004
    I probably wasn't clear. A few weeks ago I took the 2002 base tune running on the 2002 OS , aside from the diags, injectors, speedo etc, and using the throttle cracker from the 00 tune. It ran well as far as drivability is concerened, accelerates smooth, no KR, decelerates nice and virtually no surge or bucking at all but not as strong. This week I reidi the full 2000 tune on the 2002 OS except for left the trottle cracker as it was on the 2002 tune because that worked well and now it has the idle hanging for a few seconds when I come to a stop, doesn't decelerate as well and cruises a little bit when I get near 2000 RPM. I then tried the throttle cracker and follower tables from the 02 tune, helped a bit with deceleration but still have the hanging idle.
    M6,
    Jun 2005
    Quote Originally Posted by DaddySS
    Then, I'd tweak the delay/decay rates. Log the stuff I mentioned above and you'll know which one to go after.
    Jul 2005
    sounds like it needs a RAF adjustment
    Lifetime Member Doc's Avatar
    Oct 2005
    I'm with both Jeff and Marcin. As long as the RAF is good then, with the conditions you described then, the delay/decay rates are where I would start.
    www.efialchemy.com
    www.greatamericancarwar.com
    Mar 2004
    OK, I'll take a look at those and let you know what I find.
    M6,
  1. ***Need help with idle surging while coming to a stop please***
    By WICKEDOWESIX in forum Gen III V8 Specific
    Last Post: December 30th, 2009, 08:38 AM
  2. B4317 to drop idle faster when coming to a stop?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: August 4th, 2009, 06:53 AM
  3. Idle surge coming to a stop
    By slowhawk in forum Custom Operating Systems
    Last Post: March 18th, 2008, 02:41 PM
  4. Surging When coming to a stop- 10 MPH only
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2007, 10:27 AM
  5. Surging when coming to a stop
    By 12secformula in forum Gen III V8 Specific
    Last Post: December 18th, 2006, 02:01 PM
