Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Going MAFLESS and O2 less
    Mar 2005
    Default Going MAFLESS and O2 less
    hey people a question:
    though I'd have a look at the virtual VE table and see how close it was and have a play basically so I set up the MAF fail limit to "0" as per LS1 procedure then I went into O2 trim and put the losed loop temp enable up to 140 deg and LTFT enable up to 140 degrees and reflashed the PCM. Diasabled the MIL etc.
    When I started up the engine it ran fine but the fuel trims both STFT and LTFT were still trimming away happiliy as if they had never been turned off.
    What have I done wrong?
    Mike
    "Just a tune > yeah right !!!! "
    Mar 2005
    bump......no suggestions...
    Lifetime Member Chalky's Avatar
    Sep 2003
    Is that 140 C or 140 F? Sounds like you are still in CL!
    2015 Z06 A8
    Mar 2005
    140 C
    Junior Member carneb's Avatar
    The Description for {B4206} says:
    When disabled, the PCM will always use
    - {B3605} Commanded Fuel When in Open Loop (Normal) or
    - {B3647} (not available in this operating system) as the fuel mixture table without any O2 feedback as long as table
    - {B4205} Closed Loop Temp Enable is also set to it's maximum value.
    If this parameter is enabled then O2 feedback (STFT) will be used with the Open Loop table.
    If you wish to run total open loop disable this parameter and set
    - {B4205} Closed Loop Temp Enable to it's maximum value.
    Only the following values may be entered into this table:
    - Disable
    - Enable
    Does this do the trick?
    Mar 2005
    did all that....didn't work, will have another crack tomorrow, maybe I missed something
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Quote Originally Posted by The Alchemist
    Be curious to hear how you go. Going to try this very soon
    Jez
    Waiting to hear as well. Just haven't got to mine yet.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Sorry guys, I missed this discussion.
    B1506 is the key. What happens even in 'open loop' if it could be called that is the ECM will still look at the O2 sensors once it decides they are at a working state (i.e, hot enough and voltage swinging).
    Via B1506 you need to make the ECM think the O2 sensor is never ready, drop it way down in value.
    Mar 2005
    hey cool thanks GMPX...who would have thought....
  1. MAFless??????
    By Rvettej in forum Gen IV V8 Specific
    Last Post: June 25th, 2021, 12:20 AM
  2. Going mafless On a E-40...anytips?
    By FFP in forum Gen IV V8 Specific
    Last Post: August 13th, 2007, 06:40 AM
  3. Question about going MAFless
    By VortechC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 26th, 2005, 02:24 AM
  4. mafless/pcm
    By zrx1200 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2005, 01:48 PM
