i can't get my wideband to sync up w/ efi live- i set the limits in to 0v=10 and 5v=20 in the lm programmer and in the set .txt files on the efi live config. The wideband reads 0-2 AFR @ idle and goes all the way up to 50 (on EFI live scanner), whereas the AFR on innovate display is 10.2 (when efi reads 0) and is @ 70 KOEO. WTF? This is all brand new equipment and I have everything I need, I just CANNOT get the calibration corrected... The readings can vary between 2 and 25 points at any given time
thanks
