When I strated it thismorning it immediately idled very high, then came after a few seconds, can't find the the source of the flare up in the 99 02 conversion file? Coolant temp was 68* outside about the same.
2000 Camaro SS Convertible
M6,
LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
Have you edited B4604 start up rpm offset? The 02 OS version of this table adds rpm at start up where the 00 doesn't. I noticed the same thing as you after converting, and it annoyed me. When I zeroed out this table as in the 00 OS, it cured it.
Thanks, I checked that and it is the same, both zero'd out.
M6,
Another thing to look at is B5934 Idle Flare Control. The O2 settings take out more timing below 500rpm than the 00. You might try those settings. You could also play with the 02 base spark tables which, again, are less aggressive than the 00.
Progress! You're right, the flare control and the overspeed and underspeed error plus the start up air flow multplier had a dramatic affect on the problems I was chasing. Changing those to the 02 settings fixed the flare up on start, the hang when coming to a stop and the excessive underspeed on idle when first engaging the clutch. So far this is much better!!!Originally Posted by RevGTO
M6,
Great - glad it worked for you!
