In this post on LS1Tech, these equations were stated in reference to tuning the MAF.
I would like to tune the MAF on a car for which I don't have a WB.Originally Posted by RedHardSupra
The car in question is very stock. A larger MAF will be installed on the car as a favour. The VE table should be close. My WB is installed in a different car where it is not easily removable.
My question is can I use Short term or Long term trims in place of the WB reading? I can convert the % into a approx AFR and make a partial strenght correction. No WOT will be done. Just daily driving cells.
Long term trims block the VE into a low resolution correction. Short term changes alot due it being used for corrections at idle. Maybe STT will converge into a more correct value by extending the data logging session and tuning at a going down the road circumstance. Just to see the trend.
I can get these equations into a PID by myself, but wondering if it is a mistake. I have tuning using NB before, however, the end result was nothing like what I got when I started to use WB. What do you guys think?
