Results 1 to 3 of 3
Thread: DMA only for Dynamic Mode error...
    Lifetime Member McRat's Avatar
    Nov 2005
    Default DMA only for Dynamic Mode error...
    I've spent the last few days trying to do external data collection.
    I finally get everything in place, all the sensors tested, then all I can get is a cryptic error telling me to set the software to Dynamic. It IS in dynamic.
    It does not matter what PIDs I select, or whether I select PIDs at all. Same error no matter what. I can communicate with the truck, I just can't use the SCAN software at all.
    This is with V2, latest public software/firmware, a LLY that has been flashed and logged hundreds of times. The computer I'm using is new, it's a Vista32 Sony notebook.
    2005/2007 DHRA Western Drag Champion
    Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
    Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
    Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
    Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
    Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
    Nov 2005
    "One of more _DMA PIDs are selected. This Duramax ECM can only scan _DMA PIDs in Dynamic or Stream scan mode. ..."
    Does not matter if you have selected _DMAs or not.
    V7.4.2 (Build 534) ... (Build 666)
    I tried it with an XP computer and it did work though. But the software on the XP computer is 7.4.2 Build 515 / Build 644
    I'm looking into it...
  1. What is fan after run mode ?
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2010, 04:07 AM
  2. COS3 and COS5 lean cruise PE Mode AFR error
    By ringram in forum Custom Operating Systems
    Last Post: August 16th, 2007, 07:25 PM
  3. PE mode
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 02:18 AM
  4. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
