Results 1 to 6 of 6
Thread: 6.2-6sp shifting issues
    Sep 2007
    Default 6.2-6sp shifting issues
    New here, glad I found it. Have a 07-Sierra Denali that is either a race car or a dog, no inbetween. Upshifts way to early, then requires a lot of pedal to get it to downshift. The interesting part is that my wifes new Yukon XL Denali with same drivetrain does not have this problem. Her's upshifts early as well, but comes out of it quickly, easily, and seamlessly, getting the truck moving again. Seems like the solution is simple, with just a shift pattern change. Any products to help? I don't think I need any engine mods, as it has plenty of power.
    Aug 2004
    v2 is what you need to modify your trans
    Sep 2003
    Quote Originally Posted by wait4me
    Are the 6lxxE calibration files available now?
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
    Junior Member Jared Duramax's Avatar
    Feb 2008
    i got the same problem but with a yukon denali short and it is like a gas guzzling 4 banger i need to do something with it
    Jared
    2003 GMC Sierra 2500HD LB7
    285/75R16 BFG AT, Prodegy brake controller, Bilstine Shocks, Tierod sleves, Pitman and Idler supports, 5" Magnaflow Turbo Back, PPE Boost Valve, Phantom II Boost and Pyro on Pillar, BD Manifold. EFI LIVE V2 By SoCal, EDP Twin Lift Pump's, Suncoast IV 1056, Billet Input Shaft, Merchant Automotive Pump Rub Kit
    Member #3 of NC Dmax's
    Sep 2007
    A TSB came out in Oct-Nov. Once installed the shifting issues are much better. Still not great, but acceptable now.
    Feb 2008
    but when its below 70 out the truck runs like a raped ape but above 70 its a gas guzzling 4 banger so im thinking it has to do with a temperature sensor or timing tables with different temp settings ive had all the TSB updated on it and they all make it worse that originally
    Jared
  1. 4x4 shifting
    By southern in forum Gen III V8 Specific
    Last Post: May 18th, 2010, 11:13 PM
  2. 4L80E rough shifting issues
    By bekmwan in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 26th, 2009, 02:03 PM
  3. 2-3 not shifting
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2007, 11:43 AM
  4. Shifting issues 99 A4 Z28
    By mzoomora in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2006, 12:07 PM
  5. Shifting issues 99 A4 Z28
    By mzoomora in forum General (Petrol, Gas, Ethanol)
