I have a 00 WS6 M6 with a procharger. I put 47# injectors and a racetronix fuel pump. I setup the flow rate of the injectors and I'm running COS5. If I touch the throttle it will go up to 2k rpm and hang there for 3-4 seconds. I logged the desired idle flow and it averaged out at 0. I also logged snapping the throttle. I hope someone can help. Thank You.
2000 M6 COS5_0007 Auto VE Tutorial_0003 Z06 VE Table.tun
Log_Idle.efi
Log_throttle.efi
