Results 1 to 3 of 3
Thread: Injector flow base
    Lifetime Member johnv's Avatar
    Jan 2005
    Default Injector flow base
    Have a guy with a 06 6ltr thunder ute, he has had 60 # mototrons fitted for FI.
    Looking at table B4001 in his tune (injector flow base) the EFI limit is only 7.999 g/sec and values up to 9.5 g/sec will be required to set up the table for the larger injectors !!
    But if you change the units to imperial the limit is 100 lb/hr which is much higher then 7.999 in metric !!
    So is there a bug in the operating system ?
    and do we just revert to imperial on that table as a work around.
    Cheers
    John
    It was a bug with the limits set up in EFILive. It has been fixed and the fix will be available in the next update.
    Subscribe to this thread for instant notification of software updates:
    http://www.forum.efilive.com/showthread.php?t=4442
    Jan 2005
    Thanks Paul
  1. Injector flow rate
    By sinr98 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2010, 04:59 AM
  2. Injector Base Pulsewidth
    By 5.7ute in forum General (Petrol, Gas, Ethanol)
    Last Post: March 25th, 2009, 04:07 PM
  3. Injector Flow
    By Harrismarine in forum General (Petrol, Gas, Ethanol)
    Last Post: December 3rd, 2007, 07:24 PM
  4. LS7 injector flow rate (base) table?
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2007, 07:23 AM
  5. Injector Flow ?
    By DWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 02:50 PM
