Originally Posted by
joecar
B3605 Suggestions:
- set the last 3 cols to AFR 12.6;
- set rows 212-230 cols 20-50 to 14.7;
- set rows 68-86 cols 20-45 to blend in;
You don't want to go lean anywhere, and you want to be sufficiently rich under load;
I just remembered that the PE table allows you to fine tune AFR as RPM sweeps from torque peak to power peak (whereas OLFA is MAP vs temp)... in this case, if you go this way, set OLFA table to be safe: set its last 3 cols to the same AFR as the leanest AFR in the PE table (which should be at least richer than 13.2-12.7)... Then whenever the PE table commands richer than the OLFA table, the PCM just selects the richer.
