Results 1 to 2 of 2
Thread: E38 Misfire DTC
    Lifetime Member macca_779's Avatar
    Jan 2007
    Default E38 Misfire DTC
    Guys just throwing it out there to see if anyone else has seen a misfire DTC come up on an E38 before. I tuned a L98 a few weeks ago then got a call 2 weeks later that the car was running quite poorly. It was surging under large throttle inputs and basically didn't want to build RPM. I scanned it and called out a cylinder 7 misfire code as well as a similar EPA one which I can't recall exactly what it was named now. The odd thing was that I cleared the codes and the car was fine. It's like with one or both of these codes the ECM was putting the engine into a sort of limp mode. I'll be monitoring this cars progress closely, but in the meantime if anyone has seen this before have they worked out why its occuring and what the rectification is. It could of just been a spurious thing because its fine for now.
    Aug 2007
    I tuned a L76 that had a miss under high load low rpm but didn't log a miss, it really needed to come out of closed loop earlier but I was having issues with that too. I ended up altering the shift pattern to avoid the situation which seems to have worked well for now.
  1. Mystery Misfire codes?
    By Mr. P. in forum Gen III V8 Specific
    Last Post: November 5th, 2009, 05:46 AM
  2. Can't figure out this misfire, possible bad PCM?
    By bnca1980 in forum Gen III V8 Specific
    Last Post: August 13th, 2009, 12:37 PM
  3. misfire help
    By NviouSS in forum General
    Last Post: June 3rd, 2006, 06:18 AM
  4. Misfire Table
    By Honez in forum General (Petrol, Gas, Ethanol)
    Last Post: February 1st, 2005, 05:54 PM
  5. Misfire Table
    Last Post: February 1st, 2005, 01:19 PM
