Results 1 to 2 of 2
Thread: How do I make flashscan record RR?
    Jul 2007
    Default How do I make flashscan record RR?
    I connect to the RR ok thru the usb but when I try to connect using the flashscan it doesnt show the red and yellow button options to record? which controller do I select, same as for my ecu?
    AFR 205 heads, Mamo Ported FAST 90, 238/240 cam, 347 forged SB, 9 inch 3.89, 11x18 z07 wheels, svo 30, racetronix.
    You name it: all the bells and whistles
    http://www.fquick.com/99SS
    Lifetime Member Doc's Avatar
    Oct 2005
    Did you plug in the data port connector before plugging in the other end into the V2? I have seen some cars try to talk to the V2 and keep it from handshaking with the laptop. I have just gotten into the practice of pluggin in the laptop side to the V2 first. Hope this helps.
    www.efialchemy.com
    www.greatamericancarwar.com
  1. Setting the record straight on Gen IV ADM/DoD and VVT
    By TBMSport in forum Gen IV V8 Specific
    Last Post: April 2nd, 2010, 06:56 AM
  2. Replies: 8
    Last Post: September 9th, 2008, 11:08 AM
  3. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
  4. Scan Tool won't monitor or record
    By ForcedTQ in forum Petrol / Gas
    Last Post: August 25th, 2007, 12:15 PM
